@salazar: I found this post about the same issue, and I can confirm that the current nightly version immediately works when “LAN bypass” is turned off on my side. Just mentioned this as crossref!
Are you only unable to connect to fast mode when LAN bypass is turned off?
@salazar: We are unable to connect when “LAN bypass” is turned on! When it is turned off, the connection immediately works…
For me, version 2026.12.2-release solved the issue. “LAN bypass”-enabled connection is working again!
