does anybody else experience the following behavior on Android with the version v2026.11: When I use the Fast mode and choose an Entry/Exit server combination (even with Random/Random), my NymVPN is no longer able to connect. It comes until step 6/6, then seems to be “broken” because it returns to step 1/6 and then seems to be stuck in a “connection attempt loop”. I can choose different Entry/Exit server locations, it does not matter.
When I switch to Mixnet mode, everything works immediately.
I have already tried the following:
Switched from Wifi to Cell connection. No change.
Restarted my phone - no change.
Uninstalled and reinstalled NymVPN - no change.
Cleared data+cache - no change.
Even trying another VPN solution works out of the box.
My laptop with NymVPN on Windows 11 works out of the box.
Does anybody have any idea what else I can do to further check what is causing this?
@patrick.weiden@code-zm I’m sending you a test release link in DMs. The fix will go live later this week, so it would be great if you could check whether it resolves the issue on your device.
@salazar: Sorry for disturbing again. I recently (again) installed both versions after each other, i.e., the one from Github and “yours”. “Yours” now works, whereas the one from Github doesn’t.
Thanks for the update - can you also check if these issues are being caused due to bad gateways? Switch to other locations and let us know if you can connect.
@salazar: I sent the log files of the beta prerelease version from Github which does not work to the ticket.
I chose same Entry/Exit node combination (via country, not specific gateway), I chose different Entry/Exit country combinations and I chose Random/Random for Entry/Exit nodes.
In all mentioned combinations, different gateways were chosen via NymVPN for the Entry/Exit node “countries”, I did not choose any specific gateway. Even in the Random/Random setting, different countries were chosen for Entry/Exit.
I uninstalled all versions of NymVPN (Prerelease/Beta, Nightly, Release) and reinstalled Beta 3. I ran several connection attempts using Fast mode, not successful; afterwards a connection attempt with Mixnet was immediately successful. I again performed those tests over cellular and WiFi network, and again with varying Entry/Exit servers. Still the same behavior as before…
