Device:
Redmipad 6 with HyperOS based on Android 14
Clients:
Nymvpn 2026.11.3
Orbot: 17.9.5
DiagnosticTool: All passed with “OK”
Hello eveyone,
after the Update my servers werent able to establish a new connection ove the fastmode.
it goes through the step 6/6 then hangs on “connecting” and then switches the server.
previous versions has worked flawless.
Tried to make some options like anti censorship,ad blocking and orbot on/off
Nothing Changed.
Update: If i disable the “LAN bypass” it seems to work
best regards
