Yes I will add this to the frontend, thank you for the suggestion
Are Nym’s post-quantum keys supported and used by the OpenWRT app?
Hi there, has anyone successfully connected in Russia using OpenWrt? ![]()
Coming in next release! Lewes protocol will be enabled by default
I’m not sure if anyone has connected from Russia. The next release will have a circumvention transport (QUIC) option which should help you out.
What’s New in v1.30.0
Syncs the core to upstream nym-vpn-core 1.30
Quantum resistance via the Lewes Protocol
Connections now negotiate the Lewes Protocol, deriving a post-quantum preshared key for the WireGuard tunnel
Circumvention transports
A new Circumvention Transports toggle routes through bridge transports for blocked networks. The entry picker flags CT-capable gateways.
Frontend optimization
Polished LuCI interface with a faster connected view and live account/session UI.
Fixes and improvements
- Deeper connectivity diagnostics in LuCI (HTTP reachability, hybrid-transport, DNS).
- LAN routing decoupled from the kill-switch; smarter gateway blacklisting; account sync backoff.
- Hardening: owner-only control socket, retired networks filtered.
Coming next
Managed split-tunnel exclusions: exclude a device or a domain from the tunnel directly in LuCI, with no manual nftables rules / PBR.
Upgrading
opkg update && opkg upgrade nym-vpn
Or, for a fresh install:
curl -fsSL https://packages.dial0ut.org/install.sh | sh
