Please don’t mind, i just tried to help . I know it’s hard for any solo developer to build here.
NymShare now supports both options: users can either select specific gateways for serving and downloading or stick with the default of randomly chosen gateways.
Learn how to use specific gateways here: nymshare/README.md at main · valansai/nymshare · GitHub
great work so far!
I have a feature request: CLI integration
specifically, something like GitHub - magic-wormhole/magic-wormhole: get things from one computer to another, safely
Magic wormhole is great for the convenience - you simply do:
~/dev ❯ wormhole send tts/espeak_patch.py
Sending 1.4 kB file named 'espeak_patch.py'
Wormhole code is: 81-outfielder-clockwork
On the other computer, please run:
wormhole receive 81-outfielder-clockwork
Then anyone can download the file with that code. You can also specify a directory and it will zip it for you
Hi! Thanks for the suggestions. I plan to separate the server and client soon, so it’ll work on both headless systems and with a GUI.
