I recently installed Secureblue and bought a one-year subscription from NymVPN, the problem is that I don’t know how to install it. Secureblue uses run0 instead of sudo, so I can’t install it from the terminal as they indicate. Is there a way to install it? Like with rpm-ostree? English is not my first language, thank you in advance.
If it uses rpm-ostree you could install from a local rpm package. You can either build it yourself or try this. I’d recommend building it yourself because trusting someone that isn’t a well known maintainer with packages is very risky.
This should allow you to install the daemon as system package and thus might eliminate the need for sudo. This is however untested, just wanted to give you a lead.
