Hello,
Having trouble installing Nym on Pop OS 24.04. I just keep getting “E can not locate package” after running the installation scripts. Any ideas?
Thanks
Hello,
Thanks
Sorry to keep you waiting - have you tried any of the other installation methods? Let us know if you continue to see the error: https://nym.com/download/linux
The Appimage installation worked. Will this update automatically, or will I have to check for new versions?
Yea it should, and you can check for updates in app too if I’m not mistaken
