I have a problem with Nym, but only with torrents. I am using Arch Linux / EndeavourOS.
In general, the VPN works very well with YouTube streams or any other use.
However, when downloading torrents with Transmission, Deluge, or qBittorrent, I always have the same problem: the speed is very slow or sometimes almost nonexistent.
I have tried many things, but now I don’t know what else to do.
Some operators might restrict torrents. There are changes coming to the network that will disincentivise this, so you’ll have more success with torrenting. Also check if QUIC is enabled, that can reduce speeds.
Switching to different exit gateways should work if you’re seeing this type of issues.
Thanks for your replies. I’ve already tried different gateways, unfortunately without success. QUIC isn’t used for torrents. It works perfectly fine for torrents under Windows. I’ve submitted a support request.
