Split Tunneling on android
Can anyone just confirm a couple of questions please.
  1. if i use split tunneling option, when i click the shield icon next to the apps i want on, those are ommited when the vpn is switched on?
  2. can i control if it is fast or anonymous?
  3. and if so, can i have a combo of both fast and anonymous?
I am guessing 3 is a step too far lol, but just want to be clear
  1. When the shield icon is selected, that means the app should be using NymVPN.
  1. Not yet, but we’re working on this feature
  2. Only way to use this right now would be to use the app & wallet proxy mode. You can stay connected to NymVPN via fast mode and use the SOCKS5 proxy to route specific apps via mixnet. Note that it might not work for all apps. report if you encounter issues.
i will give the latter a go thanks, see if i can figure it out
