Speed in fast mode 44klb per sec
speed in fast mode 44klp per sec
Some troubleshooting tips to help with connection speeds:
  • Disable QUIC if you have it enabled
  • Choose other, more reliable gateways geographically closer to you
  • Check if you have any additional configurations enabled on your network: custom firewalls, DNS may cause issues
  • Check if you have the latest version of the app installed
If you continue to see errors despite this, share logs with the support team and we can help you investigate: support.nym.com
