I would like to highlight some important points regarding running independent nodes on the network which could pose future challenges if not addressed from the start
Issue of Obtaining a Static IP
One of the main challenges that independent node operators may face in some regions is obtaining a static IP from their service provider
Some users may rely on dynamic IPs making communication between nodes difficult or requiring temporary solutions such as using VPN services or private networks
It would be useful for the developer to consider a practical solution for this issue whether through support for virtual networks or mechanisms for dynamically discovering nodes
Network Security and Control
Using a static IP makes nodes easy to trace by location and increases the likelihood of being targeted or exploited
Knowing the nodes IPs could pose future security challenges especially if the nodes operate on public networks or directly on the internet
It is important to design strong protection and encryption mechanisms such as using an internal VPN an encrypted tunnel
Recommendation
Consider incorporating solutions to handle dynamic IPs and ways to secure the network into the service design
Provide tools that make it easy for users to run nodes even if a static IP is not available
Focus on designing the network in a way that minimizes security risks related to IP exposure while maintaining smooth connectivity between nodes
Obtaining a static IP can be a challenge for independent node operators and practical and secure solutions should be considered in advance to ensure network stability and protect node data
