Proposal for a new NIP - Opening ports 6667/6697 for IRCv3 instant messaging
Dear Nym Team,
Following the inspiring Geminispace proposal by @Ch1ffr3punk, I would like to suggest making ports 6667 and 6697 available for the Nym community.
IRCv3 is a cool and Mixnet-friendly way to communicate, compared to centralized and bandwidth-heavy instant messaging platforms. It keeps the simplicity of classic chat, but adds modern essentials like SASL/CertFP authentication, message history, multi-client support, and native TLS encryption . It is lightweight by design and ideal for the latency profile of a mixnet.
Nym community members can run their own servers with minimal resources. Modern daemons like Ergo and InspIRCd make self-hosting straightforward and privacy-focused.
To see what modern IRC is all about, I encourage people to try an open source IRCv3 client like Goguma, Gamja, or WeeChat.
I believe IRCv3 would be a valuable addition to the Nym ecosystem alongside Geminispace. If you support this proposal, please share your feedback below.
Best regards and happy mixing,
Gab
Victor Virebent
If you look at the exit policy file, you’ll find this line:
#ExitPolicy accept *:6697 # IRC SSL (REJECT to AVOID Tor DNSBL)
It’s commented out, and the reason is written right there: Tor DNSBL.
When Tor exit nodes started getting used for IRC botnet command-and-control, IRC networks responded by blocklisting all Tor exit IPs.
Tor exit operators got banned from IRC en masse. The Nym team was right to be cautious, nobody wants to inherit that mess.
But here’s the thing: that problem is specific to Tor’s architecture, not to anonymity networks in general.
Tor is an open proxy. Anyone can use it for free, no questions asked, no credentials, no limit on how many circuits you spin up.
That’s exactly what made it attractive for botnet operators.
Nym works differently. Access requires zk-nym credentials ,you can’t just point thousands of clients at the network without tickets. The existing IP denylist (Spamhaus SBL/PBL) already blocks the known botnet infrastructure at the network level.
And this proposal is for port 6697 only, TLS-encrypted IRC. Port 6667, the plaintext port that botnet C2 traffic historically runs on, stays closed.
The Tor DNSBL concern is real. It just doesn’t apply here.
Best regards
Gab
Following up,
I wrote a longer piece explaining what IRCv3 actually brings to the table,for anyone who wants context on why this protocol is worth routing over a mixnet.
The article covers capability negotiation, SASL EXTERNAL (certificate auth,no password in transit), STS (IRC’s equivalent of HSTS), message tags,server-side CHATHISTORY with configurable retention, and MONITOR for presence without polling.
The argument at the end is the relevant one for this community: IRCv3 is implementable, auditable, self-hostable, and federates without a central authority.
A client that speaks IRCv3 is a few thousand lines of code and a TCP socket, no SDK, no binary protocol, no platform dependency.
Full article: IRCv3: What Changed, and Why It Matters — Virebent Blog
If anyone wants to test the SOCKS5 path against a Ergo instance before the NIP is resolved,
the onion address is in the article footer.
Best regards
Thanks for the detailed explanation and additional context around IRCv3.
We’ll take the request for opening port 6697 into consideration during the next NIP discussion cycle.
Appreciate the write-up and testing effort.
Hi,
i’m very happy if you take in consideration my NIP.
I’m running an Ergo IRCv3 instance already accessible via a Tor hidden service.
The goal of this NIP is to enable the same access path over Nym instead.
Ergo handles TLS natively on 6697.
If the NIP discussion is easier with a single port, I’d suggest limiting the request to 6697 only and dropping 6667 entirely , plaintext IRC over a mixnet doesn’t make sense anyway.
Happy to provide test endpoints or run a live demo if that helps the decision.
Best regards
Gab
Plaintext port 6667 doesn’t make sense just because this port will leave unencrypted the last destination segment for the irc daemon .
Have a nice day :slight_smile:
Gab
Hi @merve,
Thanks for the positive feedback on the IRCv3 proposal!
Is there anything I need to provide to move this forward, or is it already queued for the next exit policy update?
Happy to help with testing or documentation if needed.
Best regards,
Gab
Hey @Victor
Your port request has been added to NIP-12 and will be submitted for operator voting as soon as possible.
The process has taken longer than usual due to increased workload on the operators’ side. Thank you for your patience and understanding.
@merve
I’m happy with this news, it fills me with joy !!! <3
Hi @merve,
Great news that NIP-12 passed and that the NTM side already shipped.
I noticed PR #6855 merged on June 24th adds IRCv3TLS (6697) to the NTM allowlist alongside EufyTLS and FiveMGameServer.
I’m testing an IRCv3-over-Nym client that goes through nym-socks5-client (Network Requester path), and as of today the public exit policy at https://nymtech.net/.wellknown/network-requester/exit-policy.txt is still showing v1.9.0, 20th May 2026, with #ExitPolicy accept *:6697 still commented out.
Since NTM and the Network Requester exit policy are separate systems , could you confirm whether the exit-policy.txt update is still pending, and if there’s an ETA? Happy to help test as soon as it’s live. I have a working client ready to go (nirc, tested end-to-end over a direct TLS connection, just waiting on the mixnet leg).
Thanks!
Gab
Hey @Victor - you are right there - let me find the core of the issue.
Thanks @serinko, appreciate you looking into it.
Quick guess in case it helps: PR #6855 seems to have only updated the NTM allowlist, not the
exit-policy.txt itself, might be two separate pipelines that need syncing.
No rush, I’ll keep an eye on the .txt and report back once 6697 goes live. Client’s ready to go
whenever it is.
Gab
Hi @serinko,
just a light check-in, no pressure, know these things take time.
Confirmed again a couple days ago:
exit-policy.txt is still serving v1.9.0/20-May with all five NIP-12 ports commented out.
Happy to help however’s useful,
Best regards
Gab
It has already been fixed, please check: https://nymtech.net/.wellknown/network-requester/exit-policy.txt @Victor
@merve that’s wonderful news.
In that case, I’ll resume phase two of development.
Best regards
Gab
Hi @merve
i ran the real mixnet test today though and found a second gap.
Tried two different live exit gateways, both still reject 6697 outright:
Domain “irc.libera.chat:6697” failed filter check.
Then i tried google.com:6697 too on the same gateways just to check it wasn’t an IRC thing, same rejection.
So it’s the port itself still closed on these nodes, not the domain.
Meanwhile plain HTTPS through the same gateways works fine, so the mixnet path itself is healthy.
Guessing the policy file updated but rollout to actual gateways hasn’t caught up everywhere yet.
Happy to retest whenever, no rush.
Gab
Maybe you were using a gateway with closed ports. Could you try these gateways instead? @Victor
q2A2cbooyC16YJzvdYaSMH9X3cSiieZNtfBr8cE8Fi1
Bw83iGD2edUrbsRC88oYSrJ5TmYpjqCRU5BkDERb6LuA
FPpLsL6t2SRwFAamtRu9L8nH8dpKuGe2UKsHurToVXq2
Thanks for the gateways!
Tried all three (qa.nymte.ch, and the two devrel.nymte.ch ones) and same result on all of them:
Same as the two community gateways I’d already tried before.
So that’s 5 independent exits now, 5/5 reject 6697.
Mixnet path itself is fine, HTTPS through the same gateways works no problem.
One of the three (nym-node-cli.devrel.nymte.ch) even shows uses_exit_policy: false in the nym-nodes API, so on paper it shouldn’t be filtering by policy at all, but it rejects the same way.
Looks like this might be a filter baked into the binary itself rather than just the downloadable exit-policy.txt, so maybe not just a rollout-lag thing.
Let me know if there’s anything else useful to try on my end.
Gab
