[Operators add-on] 2 ip addresses for node
What do you think about 2 ip addresses at one vps?
From the provider’s point of view, they don’t know about the output ip address until they request information from a data center.
Can this improve anonymity, what do you all think?
Early, my private VPN service was used 2hop + 2ip on each vps. I think, It can be done by operators here (optional).
When I had launched my mixnode first, I had launched it with two ip addresses (one for incoming traffic, the other for outgoing). It works.
HOW TO…
It does not require complicated configuration. We just buy an additional IP address from the hosting, it should automatically connect to the VPS. This IP addr will be our incoming gateway. And the default IP addr already has a default route (outgoing traffic).
Bonding: announce the additional IP addr.
