What does it take to be the best VPN for crypto? First, you should be able to pay for real privacy protections with whatever coin you want. This is why NymVPN accepts the widest range of cryptocurrencies of any VPN.
And this just got bigger with the integration of Ethereum token payments. You can now buy a NymVPN subscription with your Ethereum (ETH) tokens. Simply select ETH tokens or USDT, USDC, DAI in checkout and voila!
Nymsters can get a whopping up to 88% percent off plans - read the blog post below to learn more.
