Nym Mailer v0.1.2 released
Hi all,
the Nym Mailer server supports now TLS with Let’s Encrypt certificates, so that your messages are encrypted when sent through the Nym Mixnet. Additionally the From: header is now “Anonymous” instead of “Nym Mailer”, to be compatible with the upcoming release of Nike Mailer. You have to update your client binary so that you can continue using the pre-configured oc2mx.net Domain.
Released v0.1.3 which contains now a Config menu, so that you don’t have to use the build-in configuration in the binary and can use your, or your friends, domain, once you have set-up the Nym Mailer server.
