Nym Integration into MoaV [Developmet]
Hey y’all, this is Shayan, currently developing a “Multi-protocol censorship circumvention stack” called MoaV –Mother of all VPNs–, mainly for Iranian internet users that are currently experiencing nation wide internet shutdown.
I’ve started looking into adding Nym as one of the protocols supported, however facing some blockers that some might not be easily solvable. Sharing this github issue that I’m tracking the feasibility research and integration progress: [Protocol] Nym Operator integration · Issue #65 · shayanb/MoaV · GitHub
If anything that can help with the research / integration, please share with me (ideally on the same github issue)
Cheers :hugs:
p.s. Cross posting this from Nym Matrix, as I’m not sure how active it is there.
Update: Given that MoaV is designed to be simple (one command installation and setup), and is to be running on low hardware requirements (1-2 vCPU, 1-2GB ram), Nym node might not fit there. However, given that we have the similar problems previously seen for Sentinel dVPN, I’m thinking maybe I can create a dMoaV version that is mainly focused on decentralized VPN solutions.
We’ll get back to you
Our devs will be in touch with you over Matrix or via Github soon!
