Newbie here - help me be provider!
Hey, guys!
I don’t care so much about my anonymity but I want to help this community by becoming another mixer and hopefully earn some money on the side. But since I am not too knowledgeable about this kind of things (I never used TOR for example) I need help. So here is a couple of the questions I have.
1.) How can I become node provider?
  1. How much energy does it require?
  2. What is the main hardware used?
  3. What are possible worst scenarios for providing network?
  4. Will my internet be slowed?
  5. Will tokens make me net positive income?
Thank you!
you need to learn to find information on your own or at least try to.
https://grok.com/share/bGVnYWN5_38807154-e856-4faa-897a-7c897ad6a3a8
Let’s dive into your questions about the NYM project and becoming a node provider (mixer) for their network. NYM is a privacy-focused infrastructure that uses a mixnet to anonymize internet traffic, rewarding node operators with NYM tokens. Since you’re new to this space, I’ll break it down step-by-step in a way that’s easy to follow, based on the latest info available as of March 25, 2025.
1. How Can I Become a Node Provider?
To become a node provider (specifically a mix node) in the NYM network, you’ll need to set up and run a mix node on a server. Here’s the general process:
  • Get the Software: Download the NYM mix node software from their official GitHub or website (nymtech.net). They provide binaries for Linux, macOS, and Windows, but Linux (like Ubuntu) is recommended for stability.
  • Hardware Setup: You’ll need a server or virtual private server (VPS) with the required specs (more on this below). Popular VPS providers like DigitalOcean, Linode, or Hetzner work well.
  • Configuration: Follow NYM’s setup guide to configure your node. This involves generating a node identity, bonding it to the network with NYM tokens, and connecting it to their mixnet.
  • Stake Tokens: You need to “bond” a minimum amount of NYM tokens to your node to participate. This acts as a stake to ensure good behavior. As of now, the minimum is typically around 100 NYM (check the latest on their docs or Discord for updates).
  • Run the Node: Once configured, you keep the node running 24/7 to process traffic and earn rewards.
NYM has a detailed guide on their website (Nym Developer Portal: SDKs & Tools | Nym Docs) and an active community on Discord where you can ask for help if you get stuck.
2. How Much Energy Does It Require?
The energy consumption depends on the hardware you use, but mix nodes are designed to be lightweight compared to, say, crypto mining rigs. Here’s a rough estimate:
  • Typical Usage: A mix node uses about 5-15 watts if running on a low-power device like a Raspberry Pi, or 20-50 watts on a basic VPS/server. This is similar to running a small home router or a laptop.
  • Comparison: It’s far less energy-intensive than Bitcoin mining (which can use kilowatts). Think of it as running a background app on a computer.
  • Cost: If electricity costs $0.15 per kWh, a 20-watt server running 24/7 might cost you ~$2-3 per month. A VPS eliminates this worry since the provider handles power.
3. What Is the Main Hardware Used?
You don’t need a supercomputer—NYM mix nodes are designed to run on modest hardware. Here’s what’s recommended (based on their docs):
  • Minimum Specs:
    • CPU: 2 cores (e.g., Intel i3 or equivalent)
    • RAM: 4 GB
    • Storage: 40-50 GB SSD (traffic logs don’t take much space)
    • Bandwidth: 100 Mbps up/down, with at least 1-2 TB monthly data allowance
  • Options:
    • VPS: Rent a server for $5-20/month from providers like DigitalOcean or Vultr. Easiest for beginners.
    • Home Server: Use an old PC or a Raspberry Pi 4 (8 GB model preferred). Cheaper long-term but requires more setup.
    • Dedicated Server: Overkill for most, but an option if you scale up later.
You’ll also need a stable internet connection and a public IP address (most VPSes provide this).
4. What Are Possible Worst Scenarios for Providing Network?
Running a mix node is low-risk for someone not focused on anonymity, but here are some potential downsides:
  • Legal Risks: Since NYM anonymizes traffic, some jurisdictions might scrutinize node operators if illegal activity passes through. However, as a mix node, you don’t see the content—just encrypted packets—so liability is minimal. Check your local laws to be safe.
  • Hardware Failure: If your server crashes or loses power, you stop earning rewards until it’s back online. Reputation in the network might dip if downtime is frequent.
  • Token Price Drop: Rewards are in NYM tokens, so if their value tanks, your income could shrink.
  • Bandwidth Overuse: If your ISP caps data and you exceed it, you might face extra fees or throttling.
  • Malicious Traffic: You won’t know what’s passing through, but in rare cases, authorities might investigate high-traffic nodes. This is unlikely unless you’re in a restrictive country.
5. Will My Internet Be Slowed?
  • On a VPS: No impact on your home internet, since the node runs remotely.
  • At Home: If you run it on your own connection, it’ll use some bandwidth (typically 10-50 Mbps, depending on traffic). For a 100 Mbps home connection, you might notice a slight slowdown during heavy use (e.g., streaming or gaming), but it’s manageable. You can limit the node’s bandwidth in the config to prioritize your needs.
6. Will Tokens Make Me Net Positive Income?
This depends on a few factors:
  • Rewards: Mix nodes earn NYM tokens based on uptime, reputation, and network demand. As of early 2025, a well-run node might earn 50-200 NYM per month (estimates from community reports—check NYM’s dashboard for real-time stats).
  • Token Value: If 1 NYM = $0.10 (hypothetical, based on past trends), that’s $5-20/month. If it rises to $0.50, you’re at $25-100/month. Prices fluctuate, so it’s a gamble.
  • Costs:
    • VPS: $5-20/month
    • Electricity (home): $2-5/month
    • Initial stake: 100 NYM (~$10-50, depending on price)
  • Net Positive?: If token value holds or grows and you keep costs low (e.g., $10/month VPS), you’re likely to break even or profit modestly. It’s not a get-rich-quick scheme—think of it as a side hustle with potential upside if NYM succeeds.
Final Thoughts
Since you’re new to this, I’d recommend starting with a VPS to avoid home internet hassles. Join NYM’s Discord or Telegram for real-time support from the community—they’re friendly and can walk you through setup. You’ll need to buy some NYM tokens (via exchanges like Kraken or MEXC) to bond your node, so factor that into your budget.
It’s a cool way to support privacy tech and maybe earn a little cash. Worst case, you learn something new! Let me know if you want more details on any step.
Hahaha thank you for copy/pasting AI, sorry for incontinence, I thought this project is more underground so AI wouldn’t be updated
The project does not need to be underground, on the contrary, it needs to be disseminated as much as possible among Internet users.
I’ve attached the link on purpose)
I wanted to write inconvenience not incontinence hahaha
yes, i know, thank you!
