Hello everyone.
After update 1.1.3 Nym Binaries v2024.6-chomp Releases · nymtech/nym · GitHub when performing a new nym-node deployment and initialization (in mixnode mode) a configuration file .nym/nym-nodes//config/config.toml is generated.
In the configuration section:
##### http-API nym-node config options #####
[http]
# Socket address this node will use for binding its http API.
# default: `0.0.0.0.0:8080`.
bind_address = `0.0.0.0.0.0:8080`.
The default API port is set to 8080 which is responsible for generating the Mixnode Stats at https://explorer.nymtech.net/. This default configuration is wrong, as stated in the operator’s guide the port for “Metrics http API endpoint” must be 8000 VPS Setup - Nym Operators Guide
If you detect that the explorer does not detect the statistics correctly, it is solved by modifying the port to 8000 in this section of the config.tolm file of your mix-node:
[http]
bind_address = `0.0.0.0.0.0:8000`.
Best regards.
