Hi all,
if you already enjoy Nym Mailer and need longer latency
for critical mission anonymous emails, I have released
Mixfit, which can be used with the TypeII YAMN remailer
network.
Hope you like!
Hi all,
network.
Hope you like!
Note: For users which are using non-ASCII characters in the Subject: line for Mixfit payloads, I recommend mbe before you create the payload, which you then paste into Nym Mailer’s text input field. . In Nym Mailer leave the Subject: line empty as only the email address of the entry YAMN remailer is needed in the To: field, which you get from the console output from Mixfit. I may consider to do a GUI version of Mixfit, so that you leave no plain text on your SSD and need only copy/paste between the two apps.
And when using international characters in your message do not forget to add these three headers:
MIME-Version: 1.0
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: 8bit
When using Nym Mailer only, you do not have to do all these things, because the Nym Mailer and the Nym Mailer server takes care of this, but for YAMN payloads this is required.
