Hi all,
in case you use the nym-socks5-client with a friends nym-network-requester, set as open relay, you can send now easily anonymous emails.
Hi all,
that’s pretty awesome, thank you for sharing!
Thank you, much appreciated.
sent for coffee
and then I saw from your wallet that the NYM team also appreciated your work
accept congratulations! good work!
Thank you very much! i completely forgot my Nym wallet and now I was very much surprised to see the donations, which I appreciate very much. Thanks to you and the Nym team. But I do not know how to look up an balance explorer, because the URL in the Nym Wallet leads to a dead link.
here’s your wallet. congratulations again
just import the seed phrase into Kepl and if and if required add a Nyx chain
Thanks for the information! I will also try out Kepl.
@Ch1ffr3punk this is cool, great self-contained project
Thank you! In a couple of days I will publish some smtp relays in this thread, so that Mini Mailer users can either send anonymous email to clearnet, while using nym-socks5-client, or via Tor to .onion email addresses.
v0.1.6 released. It allows in the Configuration Tab to omit sending the Message-ID and Date header.
Portable Windows version released, so that you can use Mini Mailer v0.1.6 on a USB stick in a public library or Internet Café etc. Hope you like!
P.S. The config and template files will now be saved in
the same directory as minimailer.exe. If you plan
to use hashcash.exe it must be in the same folder.
Virus detected by microsoft defender
I have Defender and Kaspersky and all is fine.
Defender often flags Golang binaries for Windows as virus, but it is false positive. Check also VirusTotal.
Microsoft defender false positives of Go binaries on windows · Issue #1255 · microsoft/go
Hi @Ch1ffr3punk ! Thank you for building the mini mailer. The NSL council chose to reward your contribution with $NYM <3
The rewards are now delivered! See the full list of contributions in July here ![]()
Hi salazar!
Oh, WOW! Thanks so much, much appreciated! The Nym team and community is GREAT!!!
I am very sorry about not showing smtp credentials for Mini Mailer, Nym community members can use and that my reply for that is late! I had set-up a postfix MTA on my VPS, but due to lack of reputation, which is nowadays used by the big boys, the emails which I have send did not reach their destinations, like Gmail, tuta.io etc. However, I do have a mail.ru account, which allows me to create email account, with a seperate password, for clients and smtp usage only. So what I can offer for the Nym community are the credentials for a set-up with @internet.ru. Since the account is for sending emails only I can not see in the master mail.ru account who sends an email and what kind of email. I can only see the IP Number from a Tor exit node and the time n emails have been send from this account. So this should be no privacy/anonymity problem, if multiple users are using this special account and I believe that authorities in the Russian Federation do not hand over any data from this account to the 14 eyes. To sum it up. If you use Mini Mailer already and like to send clear net emails globally, with good reputation, I can DM Nym Community members the credentials. However be so kind and do not abuse this account, because I do not want to loose it and don’t want to get in possible trouble.
