Little Nym-Node Monitor
Hello Familly, I share with you a small application I made to monitor the nodes/gateways of platohedro.
For experimentation the nodes are using the old nym api and the gateways the harbor master api.
If anyone wants to use it for theirs, it’s very simple, you only have to replace the node ids and the gateway idkey :slight_smile:
Link of Repo
Good job !! Clap clap clap for a job well done :slight_smile:
Very very Thanks ! :smiling_face_with_three_hearts:
