Due to fact that no NymVPN for lesser versions than MacOS Ventura, would there be a way to install and using the latest NymVPN as a daemon via terminal only by MacPorts soon?
I’d assume it’s just because it’s been tested and verified on systems higher than Catalina.
But hey, Catalina isn’t thaaat much far back, is it?
And yeah, you can compile it yourself - and as long as you can compile it and it runs fine, then you’re good ![]()
So, why don’t you try yourself? ;]]]
Hi, check out our compatibility guide here: https://support.nym.com/hc/en-us/articles/22692547666193-What-devices-and-operating-systems-does-NymVPN-support
We set those minimum versions to develop our iOS and macOS apps in one go. The app might work on older systems - we can’t officially support or test on everything. Feel free to try it and let us know how it goes!
