Installing a daemon on Fedora Silverblue/Kinoite
I can’t get the daemon to run properly and start when I boot my computer. Does anyone have experience installing it on Silverblue/Kinoite?
I read this article, but this terminal command didn’t help: How to install NymVPN on a non-systemd Linux machine?
did you install the daemon files separately? Releases · nymtech/nym-vpn-client · GitHub
Yes, I installed the file separately (then unpacked the archive and entered commands in the terminal). I did some searching and found that ProtonVPN and IVPN have official repositories for Fedora and provide their own .repo files that can be installed via rpm-ostree. NymVPN doesn’t provide RPM packages and doesn’t support installation via special repository. Could you please correct this nuance?
