I think it is important to use NymVPN when using Tor
Hi all,
with Wireshark one can see all the Network packets travelling from/to your PC. So I thought why not look at Tor traffic to get some user friendly statistics, when not using
NymVPN. I must admit I am not familiar how Nym VPN hides Tor traffic, but everyone
should have the ability to see in an educational and hopefully easy to understand way,
what Tor does, when not using NymVPN. The project is called Tor Traffic Toolkit. I have tested it currently under Windows 11 and hope it works as well under Linux/macOS.
Had to remove the repository (temporarily) because of the Tor word Trademark issue, which was pointed out to me. I think I will use then the name Onionflow. What do you think?
Onionflow sound’s good. I wasn’t aware of Tor trademark.
Me neither … :wink: and thanks, I will use then the name OnionFlow.
Repository is back as OnionFlow.
