Help with mobile wireguard setup
Hi there, I recently switched from Mullvad to NymVPN.
I have a Homeserver that I want to reach outside my network and I’m using wireguard to make it possible. On PC I can activate two VPNs, so no issues there. On android I can’t.
With Mullvad I made it possible by having a docker stack with wireguard and gluetun, with gluetun connecting to Mullvad via wireguard configs. NymVPN does not offer wireguard configs, so my question is:
Is there a way to make my setup work, so I can access my wireguard interface for a local ip address range, but connect to the Nym services for everything else?
I’m using LineageOS on Fairphone 6.
Thank you in advance!
if the exit nym node could reach ur wireguard server it should be possible.
which port uses ur wg. server for reaching them.
regards
How would I set that up in the nym android app? The port number is non standard (51821)
U cant, this is controlled by the exit node and if the port is open.
The Workflow should be sth. like this: Nym Client → Nym Entry/Exit Node-> Ur Wg Server.
Look in the proposals if ur port is supported:
if not, u can raise up an proposal that these port will be opened.
For testing purposes i would change the port on standard wg, to see if the issue really lies on the nym connection
If u need more help may have an look in the dev node chat on matrix:
#operators:nymtech.chat ( not sure may its invite only)
regards
So, I can’t get this to work. What I understand so far is, there is no way to connect to NYM via wireguard. Sadly, this is a dealbreaker for me.
In addition, the client on Arch Linux is very unstable and it’s frustrating to use because of constant issues.
Sadly, I bought a 1 year subscription right away, instead of trying the free trial first.
Back to Mullvad. I hope NYM VPN will be more stable in a year or so, I love the concept.
Nym offers a full refund if you change your mind in the first 30 days of purchase. Don’t think it was widely requested, so it wasn’t prioritised. But now you can request new features and vote on others you like :)) here’s how
Thanks for the hint! I paid cash, so I doubt that it’s possible. I’ll request a feature!
