Edge Wallet now supports Nym
Edge Wallet, the simple to use, privacy-focused, multi-currency wallet just added support for transaction routing over Nym. You can now select single cryptocurrencies to use the nym mixnet. This brings a new level to your network privacy :antenna_bars:.
You can view the edge support documentation here to see how to enable for single assets.
This is still a new feature so they’re still working out the kinks.
It’s exciting to see collaborations between privacy projects, try it out!
