Does nym work with openvpn on a router?
Long story short i am having to connect to a router (tp link) that i can not change, but do have access to the control app. Does nymvpn support use on a router with “openvpn” option? the app will happily connect to all the usual crap stuff like nord out of the box, but has open vpn in the advanced section
Many thanks
If you mean can you run the Nym VPN client software on a TP-Link router, then the answer is very likely to be No.
Nym uses wireguard, so openvpn solutions will be incompatible.
If you can somehow flash OpenWrt to the router, you can run nym vpn: GitHub - dial0ut/nym-vpn-openwrt: Nym VPN on OpenWrt · GitHub
thank you for the info
