Can't connect to custom ports
A huge issue I came across when using NymVPN is that I cannot connect to non-standard ports. Whether I try to SSH (to a port different from 22), connect to a game server, or use any service where I need to connect to a server that listens on some random port, it just doesn’t work. Thanks for letting me use https, email and some other common protocols with common ports, that covers most of my needs, but I don’t need a VPN to function like a web proxy, it should cover all of my traffic. I used to use ProtonVPN, free tier, mind you, and didn’t have these issues.
Exit gateways in the mixnet function similar to Tor exit nodes. Traffic is allowed / denied based on an exit policy. The community can request any ports to be opened via Nym Improvement Proposals.
Here’s an example NIP: NIP-13: Nym Exit Policy Update – Opening Additional Ports for User Services
I’ve started putting together the list of ports needed for the next NIP. Feel free to add any ports you’d like us to include in the exit policy.
OK, so here’s the list off the top of my head:
Minecraft Bedrock (I don’t play it, but many do, so it’s worth adding): 19132, 19133
Luanti:
Choose a port to run the server on. The default of 30000 is recommended, and if you host several it is recommended to increment upwards. (e.g. 30001, 30002…)
Most servers abide by that rule, somewhat, so I’d recommend allowing ports 30000-30099. But there are some popular servers that don’t abide by it, so I’d also add these: 30420 (oysterity anarchy), 40001 (FFA Groundwars Evolve), 40002 (FFA Groundwars PVP), 56008 (Versus Town).
RustDesk: 21114-21119
Syncplay: 8999. Official servers (hosted on syncplay.pl) use ports 8995-8999, so it’s worth adding those too.
SSH is still an issue. I see that node exit policy allows “alternative” ports (2222, 223), but they are too common and easy to guess. Also, many game servers use custom ports (as can be seen from Minecraft and Luanti). So the only real way to fix this problem is to allow all ports (except the likes of Telnet, which are almost never used and can be abused, for example, for port scanning).
Some rather minor additions:
nightfall.city: 1900
AnyDesk (this port is not essential because 80 and 443 are also sufficient, but I’ll list it just in case): 6568
And a more important one:
SPICE: 1923
noted! thanks
Sorry for the barrage of replies.
I know some people who use Viber, so I think opening these ports would be beneficial: 4244, 5242, 5243, 7985
Source: https://help.viber.com/hc/en-us/articles/8805123374365-Open-ports-for-Viber-desktop
Same thing with WhatsApp VoIP: 3478, 4244, 5222-5228, 5242, 5349, 34784, 45395, 50318, 59234
Sources:
https://www.reddit.com/r/fortinet/comments/14kw3bf/comment/jpyodui/
Thanks everyone for the port suggestions! I’ve double-checked everything against the current Nym exit policy (v1.10.0 - 24th June 2026). Here’s the accurate breakdown:
Already Open in Current Exit Policy (No Action Needed)
Service Port(s)
SSH 22, 223, 2222
HTTP/HTTPS 80, 443, 8080
WhatsApp 3478-3484, 5222-5223, 5228, 5349
XMPP 5222-5223
IRC 6697
Syncplay 8995-8999
Minecraft 25565
Steam 27000-27050, 4379-4380
Discord 50000-65535
Not Currently Open - Will Be Added to NIP-14
  • Proxy: TCP 1080-2080, 8081-9080, 10000-10999
  • DarkIRC: TCP 9600
  • Minecraft Bedrock: UDP 19132, 19133
  • Minecraft Voice Chat: UDP 24454
  • Space Station 14: TCP/UDP 1212
  • Luanti: TCP/UDP 30000-30099, 30420, 40001, 40002, 56008
  • RustDesk: TCP/UDP 21114-21119
  • Syncplay: TCP 8996-8999 (8995 already open)
  • Star Wars: TOR: TCP 12000-12999, 20000-30000
  • Battlefield/EA: TCP 9988, 17502, 20000-20100, 22990, 42127 + UDP 3659, 14000-14016, 22990-23006, 25200-25300
  • Viber: TCP/UDP 4244, 5242, 5243, 7985
  • WhatsApp: TCP/UDP 5224-5227, 34784, 45395, 50318, 59234
  • Nightfall.city: TCP/UDP 1900
  • AnyDesk: TCP 6568
  • SPICE: TCP 1923
About the “allow all ports” suggestion: I understand the frustration, but a fully open policy would introduce serious abuse risks (port scanning, spam, malware C&C). The NIP process is the right way to handle this. If you have other specific ports you need, just list them and we’ll review.
Thanks again for the contributions!
Thanks!
A small clarification:
Service Port(s)
Syncplay 8995-8999
I can’t see any of these ports in the current exit policy:
ExitPolicy accept *:8888 # HTTP Proxies, NewsEDGE, HUSH coin
ExitPolicy accept *:9000 # WebSocket Nym
Also here:
It is not open.
I decided to bring this to your attention in case this is a mistake.
I will double check. Thanks
I will include the following ports in the next NIP proposal. We are planning to publish the proposal on Monday. If you notice any missing ports or think there are any additional ports that should be included, please add them in the comments below this message before then.
Proxy Services
Nodemaven SOCKS5 proxy services:
  • TCP 1081-2080
Nodemaven HTTP proxy services:
  • TCP 8081-8079
  • TCP 8090-9080
Proxy-seller services:
  • TCP 10100-10999
DarkFi / DarkIRC Services
DarkIRC clearnet communication:
  • TCP 9600
Minecraft Services
Minecraft Bedrock:
  • UDP 19132
  • UDP 19133
Simple Voice Chat mod:
  • UDP 24454
Space Station 14 Services
Game server communication:
  • TCP/UDP 1212
Luanti Services
Default and community server ports:
  • TCP/UDP 30000-30099
  • TCP/UDP 30420
  • TCP/UDP 40001
  • TCP/UDP 40002
  • TCP/UDP 56008
RustDesk Services
Remote desktop communication:
  • TCP/UDP 21114-21119
Syncplay Services
Syncplay server communication:
  • TCP 8995-8999
Star Wars: The Old Republic Services
Game communication:
  • TCP 80
  • TCP 8995
  • TCP 12000-12999
  • TCP 20000-30000
Battlefield / EA Services
EA authentication and services:
  • TCP 9988
  • TCP 17502
  • TCP 20000-20100
  • TCP 22990
  • TCP 42127
Game traffic and media:
  • UDP 3659
  • UDP 14000-14016
  • UDP 22990-23006
  • UDP 25200-25300
Steam related services:
  • TCP 27015-27030
  • TCP 27036-27037
  • UDP 4380
  • UDP 27000-27031
  • UDP 27036
Viber Services
Viber desktop communication:
  • TCP/UDP 5242
  • TCP/UDP 5243
  • TCP/UDP 7985
WhatsApp VoIP Services
WhatsApp voice and video calling:
  • TCP/UDP 3479-3484
  • TCP/UDP 5224-5227
  • TCP/UDP 59234
  • TCP/UDP 34784
  • TCP/UDP 45395
  • TCP/UDP 50318
Nightfall.city Services
Nightfall.city communication:
  • TCP/UDP 1900
AnyDesk Services
  • TCP 6568
SPICE Services
Remote desktop protocol:
  • TCP 1923
Sorry for the late request, I hope there’s still time to add these:
Croc: 9009-9013
Magic Wormhole: 4000, 4001
Iroh: 7842
This one should be the last (it took some time and packet sniffing to figure out, I may do some additional testing tomorrow). I can’t guarantee I won’t remember something at the last moment, though.
Telegram (group call support, STUN (UDP)): 32001-32003
And I did remember something.
Jitsi: 3478 UDP, 4443 TCP, 5349 TCP, 10000 UDP
Jitsi SIP: 20000-20050 UDP
Sources:
Proxy Services
  • TCP 1080-2080
  • TCP 8080-9080 (Note: 8080 already open)
  • TCP 10000-10999 (Note: 10000 already open)
  • TCP 9600
  • TCP/UDP 1212
RustDesk Services
Syncplay Services
  • TCP 8995-8999
  • TCP 9988
  • TCP 17502 (already open)
  • TCP 20000-20100 (already open)
  • TCP 22990 (already open)
  • TCP 42127 (already open)
  • UDP 3659 (already open)
  • UDP 14000-14016 (already open)
  • UDP 22990-23006 (already open)
  • UDP 25200-25300 (already open)
  • TCP 27015-27030 (already open)
  • TCP 27036-27037 (already open)
  • UDP 4380 (already open)
  • UDP 27000-27031 (already open)
  • UDP 27036 (already open)
Viber Services
  • TCP/UDP 5242
  • TCP/UDP 5243
  • TCP/UDP 7985
  • TCP/UDP 3479-3484 (already open)
  • TCP/UDP 5224-5227
  • TCP/UDP 59234 (already open)
  • TCP/UDP 34784 (already open)
  • TCP/UDP 45395 (already open)
  • TCP/UDP 50318 (already open)
  • TCP/UDP 1900
AnyDesk Services
  • TCP 6568
SPICE Services
  • TCP 1923
Croc Services
Croc file transfer communication:
  • TCP/UDP 9009-9013
Iroh Services
Iroh communication:
  • UDP 7842
Telegram Services
Telegram group call support, STUN services:
  • UDP 32001-32003
Luanti Services
  • TCP/UDP 30000-30099 (already open - within 12000-65535)
  • TCP/UDP 30420 (already open - within 12000-65535)
  • TCP/UDP 40001 (already open - within 12000-65535)
  • TCP/UDP 40002 (already open - within 12000-65535)
  • TCP/UDP 56008 (already open - within 12000-65535)
Minecraft Services
Minecraft Bedrock:
  • UDP 19132 (already open - within 12000-65535)
  • UDP 19133 (already open - within 12000-65535)
  • UDP 24454 (already open - within 12000-65535)
Jitsi Services
Jitsi Meet communication:
  • UDP 3478 (already open)
  • TCP 4443 (already open - within 12000-65535)
  • TCP 5349 (already open)
  • UDP 10000 (already open - within 12000-65535)
Jitsi SIP communication:
  • UDP 20000-20050 (already open - within 12000-65535)
Game communication:
  • TCP 80 (already open)
  • TCP 8995 (already open - within 12000-65535)
  • TCP 12000-12999 (already open - within 12000-65535)
  • TCP 20000-30000 (already open - within 12000-65535)
VMOS Cloud Services
Cloud device control and video streaming:
  • TCP 30443 (already open - within 12000-65535)
Magic Wormhole Services
Magic Wormhole communication:
  • TCP/UDP 4000 (already open)
  • TCP/UDP 4001 (already open - within 12000-65535)
https://nymtech.net/.wellknown/network-requester/exit-policy.txt
Note: After the NIP has been published on the forum and before it is uploaded to https://governator.nym.com, you may still request the addition of any ports you would like to include by commenting on the thread where the NIP was published. Any necessary changes can be made before the NIP is uploaded to Governator, so there is no need to rush or be concerned.
A small correction: UDP 3659, TCP 8995, and TCP/UDP 4001 are not already open.
Also, the way some of the ports are open (for example, Luanti’s) seems wrong, because the connection to a Luanti server times out or gets dropped, so maybe only TCP or only UDP is accepted when Luanti servers expect the other. It’s just speculation, but it’s really strange.
I already shared all the requested ports, the ports I removed, and all of your feedback with @serinko ahead of the NIP-14 publication. He’ll take everything into consideration before publishing it, so there’s no need to worry.
