AEC - Air Gapped Encrypted Communications released
Finally, Nym users can now use AEC in an easy to use and affordable way.
Best regards
Ch1ffr3punk
Added GL2AEC (Google Lens to AEC) to the repository so that you can use your Android smartphone (with PlugOS…) to re-generate the captured AEC QR-Codes on Android, prior sending them via the Hermes Nym Mixnet Gateway.
The Anne Frank Nym Mixnet to Usenet Gateway supports now AEC too.
Fetch and E2Q added to the AEC repository. What does it mean? With Fetch you download AEC messages from the Usenet Newsgroup alt.anonymous.messages under PlugOS, while E2Q is used to create the QR-Code for the esub with Google Lens.
alt.anonymous.messages communication is an old and battle proven way to securely communicate and with AEC
Pegasus, FinSpy or the NSA etc. can not intercept your encryption/decryption process.
https://n2n.oc2mx.net gives Nym Mixnet users the highest protection, when used with NymVPN.
Remember, same as with Tor, when the Nym Mixnet is not used properly it can’t protect you when using it wrong!
https://github.com/Ch1ffr3punk/AEC
Updated AEC to v0.1.1 (Windows only) which uses
now zbarimg.exe (available at SourceForge) for
difficult to decode AEC QR-Code images.
