A guide on how to use NymVPN in the most secure and private method possible
The NymVPN app is already a reasonable secure VPN app given its on-going security audits. However, vulnerabilities are still a problem for all opensource applications, including NYM. An exploit of the NymVPN app could decide whether an attacker can doxx your location regardless of whether you are using mixnet or double VPN.
Unfortunately, the security posture of your opsec is dependent on the OS level, not NYM VPN. Your success of mitigating malware on your system is highly dependent on your OS/anti-virus. In the event, an attacker is able to break the sandbox of NymVPN, the attacker can silently intercept traffic, doxx your real IP address, deploy spyware, and even steal password credentials.
The most secure method to use NymVPN on a laptop/PC is arguable on http://qubes-os.org/ (not an endorsement, do your own due diligence). By utilizing a Virtual Machine, you can eliminate the possibility of malware ever reaching NymVPN, by separating your VPN in its own dedicated Operating System. This way it makes it incredibly difficult for malware to escape the XEN Hypervisor and affect your standalone VM. XEN is also open source and has significantly less attack surface than traditional linux systems, Windows, Mac.
Here is how I setup NymVPN on the most secure OS
Nym does not offer wireguard configuration files by default, so the VPN APP is required to use Nym. To take advantage of mixnet, follow this guide below:
  1. Create standalone VM. Use Debian for template (preferably Trixie). Check off box for provides network
  2. Install Nym VPN:
    Follow the instructions from the official site.
    i. wget https://apt.nymtech.net/pool/main/n/nym-repo-setup/nym-repo-setup_[VERSIONNUMBER]_amd64.deb -O /tmp/nym-repo-setup_[VERSIONNUMBER]_amd64.deb
    ii. sudo dpkg -i /tmp/nym-repo-setup_[VERSIONNUMBER]_amd64.deb
    iii. sudo apt install nym-vpn
  3. Dns handling:
    i. Create script: sudo nano /usr/local/bin/nym-dns.sh
    ii. Insert the following into script:
#! /usr/bin/env bash
update_dns() {
  nym_on=$([[ $(grep -v -c "nameserver \+10.139" /etc/resolv.conf) -gt 0 ]] && echo 1 || echo 0)
  if [[ $nym_on -eq 1 ]]; then
    echo "Nym is on"
    nym_dns_ip=$(grep "nameserver" < /etc/resolv.conf | awk '{print $2}' | head -n 1)
    sudo nft flush chain ip qubes dnat-dns
    sudo nft add rule ip qubes dnat-dns meta l4proto {tcp, udp} ip daddr {10.139.1.1, 10.139.1.2} th dport 53 dnat to "$nym_dns_ip"
  else
    echo "Nym is off"
    nameserver_ips=$(grep "nameserver" < /etc/resolv.conf | awk '{print $2}')
    for ip in $nameserver_ips; do
      sudo nft add rule ip qubes dnat-dns ip daddr "$ip" udp dport 53 dnat to "$ip"
      sudo nft add rule ip qubes dnat-dns ip daddr "$ip" tcp dport 53 dnat to "$ip"
    done
  fi
update_dns
inotifywait -m -q -e close_write /etc/resolv.conf | while read -r; do
  update_dns
done
  1. Make script executable: sudo chmod +x /usr/local/bin/nym-dns.sh
  2. Run script at boot: echo "/usr/local/bin/nym-dns.sh &" | sudo tee -a /rw/config/rc.local
  3. MTU issues and killswitch:
    i. Check app for killswitch setting
    ii. disable ipv6
    iii. add the following rule: sudo nano /rw/config/rc.local
#!/bin/sh
/usr/sbin/nft flush chain qubes dnat-dns
/usr/sbin/nft add rule ip qubes dnat-dns meta l4proto {tcp, udp} ip daddr {10.139.1.1, 10.139.1.2} th dport 53 dnat to 1.1.1.1
nft add rule qubes custom-forward oifname eth0 counter drop
nft add rule ip6 qubes custom-forward oifname eth0 counter drop
nft add rule ip qubes custom-forward tcp flags syn / syn,rst tcp option maxseg size set rt mtu
  1. Make script executable if not already: sudo chmod +x /rw/config/rc.local
Now you can switch between Mixnet and Double VPN on the most secure OS. The mixnet is quite slow so be patient. If you are in a censored country, double vpn with QUIC setting turned on should work.
EDIT: Typos
Disclaimer: im not qualified to audit this post or comment on it’s affectiveness. // Very cool, thank you for sharing! Edit: if the admins/devs were smart, they’d take advantage of this gift and turn it into an official blog post!
Thanks! This setup requires installing qubes os. Its a bit of a learning curve to use but I started with a no-coding background several years ago and I was able to do it fairly well.
A similar setup could be done on a traditional OS (windows, macos) by using a virtualization software (Virtual box, UTM, Parallels) which imitates whonix’s gateway vs workstation configuration.
Would you like me to post a guide on this?
And btw, if NymVPN mods are watching, I am open to co-marketing opportunities.
I come from digibastion.com and Chirag Agrawal | Substack :slight_smile:
I think the problem is also that you can’t boot Qubes in an Internet Café or public library. How about using PlugOS?
