Is the NymVPN app on F-droid official? It seams to be stuck on version 3.0.0. Even though F-droid often is slow with updates, but not 5 weeks. It’s not even on 3.1.0.
The checksum seams fine though.
Hi, the f-droid version is official, but updates might get delayed sometimes. We’ll inform the team. Other download options on Android are available here:
Ah i was wondering about this; didnt realize FDroid was so far behind. Thanks…
Due to the way F-Droid works, it can take a long time for them to approve updates for apps.
If you’re wanting to stay up to date with the latest versions of your apps (including NymVPN), I recommend you try out Obtanium.
Open Obtanium, at the bottom tap “Add app”, and where it says “App source URL *” enter “ https://github/nymtech/nym-vpn-client/ “ or;
Underneath that where it says “Search (some sources only)” enter “nym-vpn-client”
Tap “Search”
Make sure “GitHub” is selected
Tap “Select 1” on the bottom right
Make sure you select “nymtech/nym-vpn-client”
Tap “Pick”
Then tap “Add” on the top right
This will give you the latest version of the NymVPN app at all times.
I would suggest doing this for other apps too which upload their .APK’s if you want to keep them up-to-date with the latest versions.
