So I’m thinking of purchasing NYM but I always hear bad things about VPNs in terms of how difficult they make browsing the internet with infinite CAPTCHAs and stuff. I’m also a beginner in the topic. Is this problem present with NYM users? Thanks.
hello @mohandis
first try to find out if u need/want an vpn/dvpn
nym has some advanced features like
*mixnet which is comparable atm. with tor or slightly better on some use cases.
here are an small article with the other benefits:
furthermore u could also try nym out for 7 days if u use an subscription above monthly.
moreover, the gps obfuscation opinion is a little bit outdated on this multiple choice adviser, the most vpn/dvpn clients are able to mock the gps to the destinations from the dvpn/vpn servers.
regards
Hi, I can give you a referal code so that you can try out NymVPN for 1 month, prior deciding to purchase a subscription.
We have residential IPs in-app (these are marked with streaming icons next to them) and are planning to add more.
You can select those to have a better experience and not get detected by sites easily. On regular servers, you might still get recognised as a VPN user
