Mixnet Tuning Questions
On Desktop, the “Send Traffic Continuously” option goes from Performance to Anonymity (Low to High). On Mobile, it goes from Max Anonymity to Fastest. This seems inconsistent, should both platforms use the same scale?
When you enable continuous traffic, does “High” send more traffic for better anonymity or faster speed? What happens when you turn it off, how are packets sent then, and how much?
Mobile shows “Mixing Delays” while Desktop says “Packet Mixing Profile.” Are these the same setting with different names?
Setting mixing delays to zero says it “removes mixing.” Does this mean no Mixnet at all, or is some mixing still happening? If mixing still occurs, calling it “removed” could mislead users.
The labelling on mobile (Android) version is incorrect and will be fixed with the upcoming releases.
